1.8T AEB question
bechris
I have the engine setup all is missing is ECU n harness, will the ECU from an AWP engine which is chip n immo cancel gonna work for my engine, the seller told me all i need is to change the gas pedal to an electronic one from the GTI ??.
Any advice will help me lots since im new into volkswagen oh and the engine in going into an 84 rabbit.
going from DBC to DBW is stupid..its not just adding the electronic pedal you would need to 1: put in the electronic pedal 2: wire up the pedal 3: install a electronic throttle body 4: swap the engine harness from a DBC to DBW car..or wire up the TB seperate..
so the seller doesnt know what hes talking about
but yes i believe a chip awp ecu will work with your DBC engine with out any other changes..but not 100% sure just search vortex
