jerm__
Hey guys,
this car has 2 keys because the ignition cylinder was changed, so 1 key to open the door, the second key to start the car.
Thing is the car can only be started using the remote starter. Once the car starts, then we insert the key in the ignition cylinder and turn it, then we're off.
The problem now arises when the battery died. So i tested it and it was only 11.3V which is really low.
So I got a new battery today. Pushed the remote starter button however the starter doesn't even try to crank the car.
Usually we could only start the car by first pressing on the remote starter but I tried turning the key in the ignition cylinder and the car is turning over fine, just doesn't actually start up, so the starter and battery are fine.
The issue seems to be with the remote starter, because pressing the button doesn't lead to any cranking/turning over.
Is it possible that the remote starter needs to be reset somehow?
What should I start by looking at/for?
Thanks
Thanks
