TegraTegra
Hi MR,hope you're all enjoying the beautiful weather!
So I've come across a brake issue.Today I decided to clean/lube my brakes,only the front brakes were done.When I finished I didn't think to try the brakes,I figured they were working fine(prior to working on the brakes everything was tiptop) and about an hour ago I go to drive my car. I get in and pump the brakes to build the pressure,then I start the car and the pedal go straight to the floor.
Weird?
I decide to bleed the brakes,thinking that's the issue,when I remove the caliper brake fluid starts to slowly flow out(2 piece caliper) so maybe air got in.I bleed all 4 just to make sure,the passenger side had the most air in it.I get back into the car and it's the same shit,pedal goes right to the floor there is no pressure whatsoever.
Any suggestions as to what it could be?Brake booster?master cylinder? Again,the car was braking perfectly before all this. And there seems to be no leak.
Thank you!!
Weird?
Thank you!!
