Daso
Interesting read from another board, he's right and Im not retyping it all up myself. This is the quick collection of info.
Here is the link to the original thread with complete info: http://www.7thgencivic.com/forums/showthread.php?t=203041
This deals with the civic which is rated to use regular gas in the car's manual.
part 1 said:I'm not sure what kind of expert opinion you are looking for. But if you are running 93 octane, you ARE losing power, and you ARE going to build up crap and contaminants in your engine much quicker. They always say 87 or higher, because of the fact that some places may only offer 88 or 89.
You are wasting money, you are losing power, and you are gonna have a fairly gunked up engine by the time you get up there in mileage.
I'll explain this again since you seemed to have missed the technical explinations. The only thing octane rating is, is resistance to detonation and heat. The higher the octane, the more heat required to get the mixture to ignite.
Hence the reason cars with higher compression engine or turbos require premium. Cars with turbos, etc, and with higher compression tend to have their mixture get much hotter in the combustion chamber before the ignition spark. Using a lower octane gas in a car that requires premium causes premature detonation (which is bad, duh) since the heat detonates the lower octane gas.
Likewise, if you are using higher octane gas in your civic, the mixture may not get hot enough in your combustion chamber to burn completely through. This leaves excess fuel/air mixture in your combustion chamber during the exhaust stroke, causing a loss of power and buildup of excess contaminants. Stop using 93 octane, because you're losing power and you're pissing money away. This also burns your valves and over time you will burn through them.
As for using high octane gas and nitrous, this is somewhat a paradoxical situation. Nitrous can benefit from using higher octane gas, since the oxidization process induced by nitrous causes the mixture to super heat. again higher octane gas is more resistant to heat, therefore will help prevent detonation when spraying.
however, when you're not spraying, you're back into the category above, where it's causing loss of power and excess waste and contaminants.
As for using 100 octane gas in your car, I'd advise against that in a very cautious sense. The addatives in higher octane gas worsens the effect you're seeing here, even if you're using nitrous. Turbos can use it if they crank up their boost to the point that they'd benefit from it. However, most don't do that unless they've been tuned for it, becuase running high octane gas and high boost without being tuned is a very dangerous combination to gamble with.
If you see some ricer in his n/a civic filling up with 100 octane, point and laugh, because everyone else who actually knows what they are doing, will certainly be laughing along with you.
Oh and I found out the thing with the injectors. The addative that they use to give gas its higher octane can cause premature injector failure, injector misfires, etc, if your injectors were not made for that kind of fuel. This is an extreme case and few and far between, but it can happen, and does happen. I have to go back and look, but the addatives cause buildup on the injectors, leading to the above said failures. However, this is not always the case, so really, it's hardly worth mentioning.
This is SCIENTIFIC FACT! Methanol is completely different than using pump gas. You can't even compare the two.
No, higher octane gas does not burn more cleaner, nor does it burn more completely.
ALL THE OCTANE RATING MEANS IS THAT IT IS MORE RESISTANT TO DETONATION AND HEAT!!!
And as for the person who got better mileage with 89 than 87. Assuming your car isn't FI'd then you did NOT get better mileage just because you used higher octane. There are too many other factors involved to do an experiment like that. The ONLY case where this would be is if your car was detonating for some reason, but you'd get a CEL if something was that majorly wrong.
Also, the whole "well premium gas has more cleaners in it to help your car". wrong. government regulations prevent this. the only difference is the addative used to increase octane rating.
Once again. Higher octane gas is more resistant to heat and detonation. (this also means it takes longer to burn, which is WHY if you DONT have a car set up for premium you'll eventually burn through your valves). If you are going to run premium you have to tune for premium. you would have to advance your timing 2 degrees and retard your exhaust valves in order to allow the mixture to burn through completely before the scavaging of the chamber.
Here... so you know I'm not talking just "hearsay"
this was in a pdf i found at the american petroleum institute. here are some excerpts. i believe this was also hilighted on the service advisor web site.
WHAT IS OCTANE RATING?
Octane, by definition, is the resistance to burn or detonation. The higher the rating, the slower the burn when ignited during the compression burn cycle of the piston. The higher octane allows for better control of burning for high compression engines. So we want to match the correct octane rating of the gasoline to the engine design to ensure complete burning of the gasoline by the engine for maximum fuel economy and clean emissions.
I THOUGHT GASOLINE WITH HIGHER OCTANE REDUCED ENGINE KNOCK?
It did in older engines using carburetors to regulate air/gas mix They cannot as accurately regulate the air/fuel mix going into the engine as a computerized fuel injector. Carburetors need adjustment, as a part of regular maintenance, to keep the air/fuel mix as accurate as possible. So many times, these adjustments were not made regularly causing too much fuel to be mixed with the air. When this happened the gasoline would not burn completely soaking into carbon deposits. This would cause a premature ignition of the gasoline due to the intense heat in the engine cylinder creating "engine knock." When this happened, people would change to the higher octane/slower burning gasoline to resist the premature burn, thus minimizing the knocking problem. And it worked. Good solution.
However, since the middle to late 80’s, engines are designed to use fuel injectors with computers to accurately control the air/fuel mix under all types of temperature and environment concerns. However the accuracy of the fuel injectors and computers is based on using the recommended gasoline for that engine.
Most cars are designed to burn regular unleaded fuels with an octane rating of 87. If the vehicle needs a higher octane rating of 89-93, there is documentation in the owner’s manual, as well as possibly under the fuel gauge and by the fuel fill hole. Usually you will see this rating for high performance engines only.
WHAT IF I PREFER TO USE GASOLINE WITH HIGHER OCTANE RATINGS?
You can, but there are no real benefits, other than the gasoline manufacturers making more money off of you. When you use a fuel with a higher octane rating than your vehicle requires, you can send this unburned fuel into the emissions system. It can also collect in the catalytic converter. When you over stress any system, it can malfunction or not do what it was designed to do properly. In the early 90's, an early warning symptom was a rotten egg smell from the tailpipe. Easy fix, go back to using regular 87 octane gasoline. The rude odor usually disappears after several tanks of gasoline.
DOESN'T HIGHER OCTANE GASOLINE HAVE MORE CLEANING ADDITIVES THAT ARE GOOD FOR MY ENGINE?
No. Government regulations require that all gasoline contain basically the same amount of additives to clean the injectors and valves. The only differences are the type to help create the different octane ratings. All gasoline burns at the same rate, it is the additives that create the different octane ratings for the different types of engines.
http://auto.howstuffworks.com/question90.htm
And here's from the federal trade commission.
http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm
