Luc
I tought of doing like last year, keeping you guys informed of what is happening with my engine (See post : It has begun) ! Some peoples were interested and tought of doing it for this winter too !
Ok, first of the car is at HT Turbotech, (www.htturbotech.com). Very good guys, very good knowledge and good background (see their web site for detail). The shop was highly recomended by Adam (323 - miata - Suby) and I can see why !!
Target :
Street set-up : 15-16 psi with 300whp +
Race : 500hp (engine HP) (Won't use it much, but its just a barrier I want to brake, no one EVER made more than 460-470 hp on a j-body )
Lost will be done this winter, here is the breakdown :
Transmission :
-Swap for a getrag transmssion
-Cryotreated gears
-Differentiel Quaife
-Axels level 3 500hp (driveshaftshop.com)
-Bully clutch stage 3
-Fidanza Flywheel aluminium (8 lbs)
-B&M short shifter
Turbo stuff :
-Turbo mitsubishi (Reason : Very small yet capable of very high boost)
-Turbonetics wastegate
-Custom exhaust manifold en stainless 316L et collecteur en SS 321
-Custom downpipe
-52 lbs/hrs Injectors
-Walbro fuel pump
-Front mount intercooler up&down flow
-3" exhaust en stainless steel
-Polished aluminium piping
-BOV (Not sure which one yet !)
Engine Stuff :
-AEM EMS custom install (Adapt wiring harness to AEM EMS plug (none avaliable for my car), and adapt all sensor output voltage range)
-Upgraded ignition system (Coils, wires, ...)
-Relocated battery to trunk !
Here is the pictures of the stuff that came in (More tomorrow, when I come back from HT) :
Axels level 3 (500 hp/tq)
Target :
Transmission :
-Cryotreated gears
-B&M short shifter
Turbo stuff :
-Custom downpipe
-Walbro fuel pump
Engine Stuff :
