[h=1]OutPower Releases Sleek New Portable Battery Charger[/h]
http://www.montrealracing.com/wp/wp...e-un-nouveau-survolteur-de-batterie-portable/
If you’ve ever worked in a garage, you know that battery chargers can be big, hefty, clunky things to lug around. OutPower changes all that with the release of their new product which literally fits in the palm of your hand and can boost your vehicle with power to spare.
Founded in 2014 by a financial analyst in the Tech industry, OutPower is a Canadian-owned corporation that is making waves in the automotive market with the new product. It’s the smallest and lightest portable jump starter on the market today.
The OutPower device uses a high capacity and high power battery of 7500 mAh with a peak current of 400 amps. It’s fast charging and has a low self-discharge rate. When fully charged, the device can boost up to fifteen (yes fifteen) vehicles on a single charge.
With its sleek design, one could actually mistake it for an Apple iPhone. In fact, the OutPower device also functions as a charger for all your portable electronic devices. Rather than waste time and money with cheap, low efficiency, flimsy portable chargers, OutPower will power up your iPhone, Galaxy or any other Devices with usb output many times over.
Very few people carry a booster pack in their cars because of the size and weight. The OutPower device changes all that and gives the consumer the added safety of knowing that a boost is always there when you need it. For us Canadians, that translates to peace of mind during our harsh winters.
Functionality couldn’t be any easier. Booster cables and charging connectors come standard and there are no buttons to press. The device powers down safely on its own after every charge. To recharge, simply plug it into any 120V household outlet and within two hours it’s fully powered.
On a full charge the device can deliver approximate fifteen boosts to vehicle batteries and up to four complete charges for phones. A full charge can be held on idle for up to 3 months.
So if you’ve never been stranded with a dead car battery or have never left the house with your smartphone not charged enough to last the rest of the day than count your blessings, but if you can relate than this flagship device from OutPower is for you.
For now, the device is only available for purchase on their website www.outpower.ca and retails for a price of $199.
MontrealRacing.com members who wish to purchase an OutPower device will be entitled to limited time only exclusive 15% rebate. Use coupon code mtlracing15 at checkout.
[h=1]OutPower dévoile un nouveau survolteur de batterie portable[/h]
Si vous avez déjà travaillé dans un garage, vous savez que les chargeurs de batterie peuvent être gros, lourds et difficiles à déplacer. OutPower change tout cela avec la sortie de leur nouveau produit qui est pas plus grand qu’un téléphone intelligent et peut survolter votre véhicule avec de la puissance à revendre.
Fondée en 2014 par un analyste financier qui travaille dans l’industrie de la technologie, OutPower est une société canadienne qui fait des vagues dans le marché de l’automobile avec ce nouveau produit. Il est l’appareil le plus petit et le plus léger qui est capable de survolter un véhicule sur le marché aujourd’hui.
L’appareil OutPower utilise une batterie haute capacité et haute puissance de 7500 mAh avec un courant maximal de 400 ampères. Il se charge rapidement avec une faible consommation d’énergie. Lorsqu’il est chargé complètement, l’appareil peut survolter jusqu’à quinze (oui quinze!) véhicules avec une seule charge.
Avec son design élégant, on pourrait effectivement le méprendre pour un iPhone d’Apple. En fait, il fonctionne également comme un chargeur pour tous vos appareils électroniques portables. Plutôt que de perdre du temps et de l’argent avec des chargeurs portables fragiles et de faible efficacité, OutPower peut charger votre iPhone, Galaxy ou tout autres appareils avec sortie USB à plusieurs reprises.
Très peu de gens transportent un chargeur traditionnel dans leurs voitures en raison de la taille et du poids. OutPower change tout cela et donne au consommateur la sécurité supplémentaire de savoir qu’un survoltage est toujours là quand vous en avez besoin. Pour nous, les Canadiens, il s’agit de la paix d’esprit durant nos hivers rigoureux.
Côté fonctionnalité, il ne pourrait pas être plus facile d’utilisation. Les câbles de démarrage et les connecteurs pour recharge sont inclus et il n’y a aucun bouton à presser. L’appareil s’éteint en toute sécurité après chaque recharge automatiquement. Pour le recharger, il suffit de le brancher sur une prise 120V de maison et dans les deux heures, il est entièrement chargé.
Sur une charge complète l’appareil peut survolter à peu près quinze véhicules et jusqu’à quatre recharges complètes pour les téléphones. Une charge complète sans utilisation peut être tenue jusqu’à 3 mois.
Pour le moment, l’appareil est seulement disponible à l’achat sur le site www.outpower.ca et se vend au prix de 199$.
Les membres MontrealRacing.com qui souhaitent acheter un appareil OutPower auront droit à un rabais exclusif de 15% pour un temps limité. Utilisez le code coupon mtlracing15 lors du processus d’achat.
