Luc
Bon, il est temps que je me départisse de ma voiture. Je passe à autre chose. C'est une sunfire 1997, 2 portes manuelle. 2.2L hautement modifié, environ 75 000km. (N'as pas rouler de octobre 2004 à printemp 2009).
10 000$ négo
Contactez moi par e-mail : lucbertrand@videotron.ca
Engine:
Engine work done by Tom (www.tkrace.com)
-Stage 3 port& polish with chamber work
-intake port match-radius upper intake
-Triple angle race valve job
-Eagle Rods
-Custom JE pistons 8.0:1 and 0.025 overbore w/ Plasmamoly rings
-Modified block (overbore, O-rigned, ...)
-Custom fitted 65mm throttle body and modified intake manifold
-Custom ARP head studs
-Crane Cam GOLD PRO 1.6 roller rockers
-Clevite bearings
-Melling oil pump
-One piece Stainless Valves (oversize 1mm intake valve)
-Heavy duty valve springs and retainers
-Custom camshaft grind
-Custom valve bronze guides
-Turbo boss Upper engine mount
-Rksport lower engine mount
-Différentiel Quaife
-Swap de transmission pour une de sunfire 2002
-Axels de driveshaftshop (500whp ready)
-Bully clutch stage 3
-Fidanza Flywheel aluminium
-B&M short shifter
Turbo works (en progression) (www.htturbotech.com et Chag Autosport)
-Turbo mitsubishi TD05H Evo 3
-Turbonetics Evolution wastegate
-Custom exhaust manifold en stainless 316L et collecteur en SS 321
-Custom downpipe
-Upgraded injectors
-Walbro fuel pump
-Front mount intercooler up&down flow
-3" exhaust en stainless steel
-Polished aluminium piping
-Engine management Autronic
-Déplacement de la batterie dans la valise
-Upgraded ignition (coils, wires, ...)
Suspension/Wheels/Brakes:
-Mags FOOSE 18"
-Pneus Falken
-Baer big brake kit (avant et arrière)
-Tower Brace (front) GM one piece
-Tower Brace (rear) RSM
-APEX springs (1.6" drop)
-Koni reds front and back
-Rear Rksport sway bar w/ poly bushings
Exterior:
-Rksport StreetFire Body Kit
-Custom Hood eyebrows
-Shaved Trunk
-Painted Door handles
-M3 Mirrors
Audio:
-Alpine CVA-1004 in-dash 6.5" screen
-Concept DVD/SVCD/VCD/CD/CD-RW/MP3 player
-Infinity 6 1/2" speakers in front
-Polk Audio 6x9 speakers in back
-Alpine 12" type R x 2 in custom enclosure
-Kenwood KAC-849 600watts amp
-Kenwood KAC-929 1000watts amp
-Lightning audio 1 Farad Cap w/ digital display
-All in custom trunk set-up
10 000$ négo
Engine:
-Eagle Rods
-Clevite bearings
-Melling oil pump
-B&M short shifter
-Custom downpipe
-Upgraded injectors
-Walbro fuel pump
-Mags FOOSE 18"
-Pneus Falken
Exterior:
-Shaved Trunk
-M3 Mirrors
Audio:
