240Sx Stuff to read before asking a question.
Other sites with info:
www.club240.com
www.240sxforums.com
www.zilvia.net
www.npclub.com
www.neo240sx.ca
www.topnissansites.com
Thread intéressant pour commencer à connaitre les 240sx
S13
http://www.neo240sx.ca/phpbb/viewforum.php?f=7
S14
http://www.neo240sx.ca/phpbb/viewforum.php?f=8
Spring rates (Props to Halo)
s13 Spring Rates
Stock '90 (from FSM):
_ _ _Front & Rear: 112 lb/in (base)
_ _ _Front & Rear: 123 lb/in (sports package)
Stock '92 (from FSM)
_ _ _Front & Rear: 102 lb/in _ _
_ _ _Front & Rear: 110 lb/in w/ HICAS
Eibach ProKit
_ _ _Front: _114-200 lb/in | -1.8"
_ _ _Rear: _ 114-148 lb/in | 1.6"
Eibach Sportlines
_ _ _Front: _137-230 lb/in | 2.2"
_ _ _Rear: _ 128-200 lb/in | 2.1"
Ground Control (default springs)
_ _ _Front: 6.5 kg/mm | 425 lb/in
_ _ _Rear: 4.4 kg/mm | 250 lb/in
KGMM S21 Sport
_ _ _front: 3.2 kg/mm | 179.2 lb/in
_ _ _rear: 2.6 kg/mm | 145.6 lb/in
KGMM S21 SuperSport
_ _ _front: 4.6 kg/mm | 257.6 lb/in
_ _ _rear: 3.8 kg/mm | 212.8 lb/in
KGMM S21 Racing
_ _ _front: 6.6 kg/mm | 369.6 lb/in
_ _ _rear: 5.2 kg/mm | 291.2 lb/in
Suspension Techniques: 1.3" drop
_ _ _Front: _206 lb/in | 1.3"
_ _ _Rear: _ 155 lb/in | 1.3"
5Zigen R-Rate
_ _ _Front = 2.4-5.2 kg/mm | 134-291 lb/in | 1.3"
_ _ _Rear = _1.9-5.0 kg/mm | 106-280 lb/in | 1.1"
_ _ _
Tein HA
_ _ _Front = 6 kg/mm | 336 lb/in
_ _ _Rear = _5 kg/mm | 280 lb/in
Tein HE
_ _ _Front = 8 kg/mm | 448 lb/in
_ _ _Rear = _6 kg/mm | 336 lb/in
Tein RA _
_ _ _Front = 10 kg/mm | 559 lb/in
_ _ _Rear = _ _8 kg/mm | 448 lb/in
Tein RE
Tein RS
Tein FLEX
_ _ _Front = 5 kg/mm | 280 lb/in
_ _ _Rear = _4 kg/mm | 224 lb/in
Tein S.Tech
_ _ _Front = 3.2 kg/mm | 179 lb/in
_ _ _Rear = _2.9 kg/mm | 162 lb/in
Tokico
_ _ _ Front = 160 lb/in
_ _ _ Rear = 160 lb/in
Whiteline Springs
_ _ _Front: 155Lbs/in | 35mm
_ _ _Back: 165Lbs/in | 40mm
Zeal Function B-6
Sreet Spec:
_ _ _Rear = 5 kg/mm _| 280 lb/in
Circuit Spec:
_ _ _Rear = 7 kg/mm _| 392 lb/in
s14 Spring Rates
Apexi N-1 Coilovers
_ _ Front = 8 kg/mm | 448 lb/in
_ _ Rear = _6 kg/mm | 336 lb/in
kg/mm DR21
_ _ _Front = 4.8-3.0 kg/mm | 269-168 lb/in
_ _ _Rear = _4.0-2.8 kg/mm | 224-157 lb/in
kg/mm DR Racing
_ _ _Front = 6.6-3.2 kg/mm | 370-179 lb/in
_ _ _Rear = _5.2-2.4 kg/mm | 291-134 lb/in
RSR Hard Springs
_ _ _Front = 5.0 kg/mm | 280 lb/in
_ _ _Rear = _4.2 kg/mm | 235 lb/in
TANABE SuperH
_ _ _Front = 3.0 kg/mm | 168 lb/in | -28mm
_ _ _Rear = _4.0 kg/mm | 224 lb/in | -9mm
TRUST Sport Springs
_ _ _Front = 2.6 kg/mm | 146 lb/in | -25mm
_ _ _Rear = _2.6 kg/mm | 146 lb/in | -25mm
HKS Super Sports
_ _ _Front = 4.14 kg/mm | 232 lb/in
_ _ _Rear = _3.46 kg/mm | 194 lb/in
Tein HA kg/mm
Tein HE
Tein RA
Tein RE
Tein RS
Tein FLEX
Tein S.Tech
_ _ _Front = 4.8 kg/mm | 269 lb/in
_ _ _Rear = _4.4 kg/mm | 246 lb/in
Whiteline Springs
Zeal Function B-6
Sreet Spec:
Circuit Spec:
Originally posted by sspikey
My children you have all learnt well:bigup: :cool:
Funk captain and Mr shoe are both now promotoed to 5 star angry sspikey members. congrats and i cant believe im saying this
this NISSAN thread ROCKS. first thread on this section ive liked till now :bigup: :bigup:
Why is there an Atari Teenage Riot song that comes to mind when I read this?
This thread'll stay a Sticky for a long time I hope :)
Originally posted by AudioAltima
All the stuff in this thread are reposts... You guys have all been demoted back to 1 star!
Ryan you have no stars haha you stink :p
damn fwd moderators :bigup: :mad: :D :D
:D:D:D the idea is to keep newbies from asking questions that are too easily answered...
Since most won't search there's no problem in it being a repost
What about me bit*h !!
:p
engine swapping info and ideas
Turbo KA24DE [more info]
Swap Difficulty: 1
Aftermarket Support: 3
Donor Car(s): S13 (1991+ US model), S14 (all US models), Hardbody (pick-up)
Stock Horsepower: 155hp (157ps) @ 5600rpm *before turbo install*
Stock Torque: 160lb/ft (22.2kgm) @ 4400rpm *before turbo install*
Redline: 7,500rpm
Good: cheap, fast, less work than a swap
Bad: reliability issues in some cases when running med/high boost sustained
Engine Cost: $800-1,500 (a few hundred more if it's rebuilt or has some parts upgraded/strengthened)
Install Cost: n/a (everything is installed other than turbo) OR $200-500 (to install a new KA where your old KA was)
Modified Horsepower Ceiling (stock internals): 250-350hp
CA18DE-T [more info]
Swap Difficulty: 4
Aftermarket Support: 4
Donor Car(s): Silvia (1989-1990) and 180sx (japan)
Stock Horsepower: 173hp (175ps) @ 6400rpm
Stock Torque: 166lb/ft (23.0kgm) @ 4000rpm
Redline: 8,500rpm
Good: higher redline and cheaper than SR20DET with about the same potential, iron block
Bad: less parts support (esp in the US), weaker head gasket than SR20DET
Engine Cost: $2,000-3,000
Install Cost: $1,000-2,000
Modified Horsepower Ceiling (stock internals): 300-400hp
SR20DE-T (S13) [more info]
Swap Difficulty: 4
Donor Car(s): Silvia K (japan), Kouki 180SX
Stock HP: 203hp (205ps) @ 6000rpm
Stock Torque: 202lb/ft (28.0kgm) @ 4000rpm
Redline: 7,500rpm
Good: great output for the price with very good potential
Bad: less output than an RB25 and weakest (stock) SR20DET, aluminum block
Engine Cost: $2,500-3,500
Modified Horsepower Ceiling (stock internals): 350-450hp
SR20DE-T (S14) [more info]
Swap Difficulty: 4
Stock Horsepower: 217hp (220ps) @ 6000rpm
Stock Torque: 202lb/ft (28.0kgm) @ 4800rpm
Redline: 7,500rpm
Good: slightly better output than the S13 SR20DET
Bad: VVT can be an issue when modifying heavily, aluminum block
Engine Cost: $4,000-5,000
Modified Horsepower Ceiling (stock internals): 350-500hp
SR20DE-T (S15) [more info]
Swap Difficulty: 4
Stock Horsepower: 247hp (250ps) @ 6400rpm
Stock Torque: 202lb/ft @ 4800rpm
Redline: 7,500rpm
Good: ~250hp stock, usually very low mileage, better condition than s13 or s14 engines (in most cases)
Bad: 6 speed tranny is somewhat weak, so if you plan to increase the hp much you want to swap it for the ka tranny or an s13/14 tranny, VVT can be an issue when modifying heavily, aluminum block
Engine Cost: $5,000-6,000
RB20DE-T [more info]
Swap Difficulty: 3
Donor Car(s): Skyline R31
Stock Horsepower: 207hp (210ps) @ 5600rpm
Stock Torque: 180lb/ft (25.0kgm) @ 4000rpm
Redline: 8,000rpm
Good: deeper engine sound, stronger than the SR20DET, more stock horsepower, iron block
Bad: cost
Engine Cost: $2,500-3,000
Install Cost: $2,000-2,500
Aftermarket Support: Fair
Modified Horsepower Ceiling (stock internals): 400-450hp
RB25DE-T [more info]
Swap Difficulty: 3
Donor Car(s): Skyline GT-S (R32, R33, R34)
Stock Horsepower: 247hp (250ps) @ 6000rpm
Stock Torque: 217lb/ft (30kgm) @ 4800rpm
Redline: 8,000rpm
Bad: cost, replacement parts availability
Engine Cost: $5,000-6,500
Install Cost: $2,500-3,000
RB26DE-TT [more info]
Swap Difficulty: 2
Donor Car(s): Skyline GTR (R32,R33,R34)
Stock Horsepower: 316hp (320ps) @ 6800rpm
Stock Torque: 289lb/ft (40.0kgm) @ 4400rpm
Redline: 8,000rpm
Good: huge potential, high horsepower stock, iron block
Bad: AWD tranny can't be used without lots of modification and custom work. TT setup can be retained, but it's much easier to convert it to a single turbo. RB25 tranny (5 speed rather than RB26 6 speed) because of clearence and fit issues.
Engine Cost: $7,000-8,000
Install Cost: ~$3,000 (AWD and TT setup will be in excess of $15,000 for install)
Modified Horsepower Ceiling (stock internals): 500-600hp
RB30DE-T (hybrid) [more info | head conversion how-to]
Swap Difficulty: 3
Donor Car(s): Australian (block; RB30ET 3.0L SOHC) / Skyline GTR or GTS-T (head; RB25, RB26, or RB20)
Stock Horsepower: ?hp (?ps) @ ???rpm
Stock Torque: ?lb/ft (?kgm) @ ???rpm
Redline:
Good: good potential, iron block, cheap engine, when modified produces large hp numbers at low revs
Bad: age, replacement parts availability, block is hard to find, RB20 head requires lots of work to fit correctly
Engine Cost: n/a
Install Cost: ~3,000
Modified Horsepower Ceiling (stock internals): 350-400hp
VG30DE-TT [more info]
Swap Difficulty: 3
Donor Car(s): 300ZX TT
Stock Horsepower: 300hp (304ps) @ 6400rpm
Stock Torque: 283lb/ft (39.3kgm) @ 3600rpm
Redline:
Good: very unique and a decent engine for heavy modification
Bad: huge cost for custom fabrication
Engine Cost: $4,000-6,000
Install Cost: $10,000-20,000+
Modified Horsepower Ceiling (stock internals): 450-550hp
VQ30DE(K) [more info]
Swap Difficulty: 2
Donor Car(s): VQ30DE in A32 Maxima(1995-1999 US model), VQ30DEK in A33 Maxima(2000-2001 US models)
Stock Horsepower: 190 hp @ 5600 rpm(A32 VQ30DE), 222hp @ 6400rpm(A33 VQ30DEK)
Stock Torque: 205 lb ft @ 4000 rpm(A32 VQ30DE), 217 lb ft @ 4000rpm(A33 VQ30DEK)
Redline: 8,000 rpm
Good: Can be cheap, good low-end, lightweight, very turbo friendly for an NA motor.
Bad: Aluminum block, lack of top end on non DEK motors. Note: Can be fixed with variable intake manifold from Courtesy Nissan. Needs Pathfinder tranny.
Engine Cost: $400+
Install Cost: N/A
VQ35DE [more info]
Swap Difficulty: 2
Aftermarket Support: 2
Donor Car(s): 350Z, G35, kouki Maxima, kouki Altima, kouki Pathfinder
Stock Horsepower: 287hp (291ps) @ 6,200rpm (350z/G35), 245hp (249ps) @ 5,800rpm (Altima)
Stock Torque: 274lb/ft (38.0kgm) @ 4,800rpm (350z/G35), 246lb/ft (34.2kgm) @ 4,400rpm (Altima)
Redline: 6,600rpm
Bad: huge cost for custom fabrication, engine taken from a kouki Altima or Maxima will need a RWD trans
Engine Cost: $5,000-7,500
Modified Horsepower Ceiling (stock internals): n/a (350-400hp est.)
Hillini says
KOUKI= After = après
on dit kouki quand il y a eu une evolution du modele ! par exemple S14 normal c tenshi pour avant et S14A kouki pour la version d'apres !
mais c pas seulement les S14 qui son kouki les 180sx aussi mais on n'a pas les pas au canada !
SR20 Instalation cost .... info
feel free te edit !!!
coz i think u can get it done for less but what eva ...
(FROM NPCLUB.com)
UN GRAND MERCI A mixdrc POUR CES INFORMATION
Les pièces et les coûts reliés au swap
Pour avoir un SR20DET S13 red-top dans une 240sx 89-98 pour 205 à 250hp
moteur et transmission 2000$
ECU s'il n'est pas inclus avec le moteur 300$
Installation chez Automotion 1500$ + filage
ligne d'exhaust 800 à 1000$
Intercooler 500 a 1500$
Blow of valve 300 à 500$
Air flow with ignition chip 300 à 500$
Boost gauge autometer 100$
Fuel pump Z32 ou Walboro 250 à 500$
Temp exhaust gauge autometer 250$
Boost control 5$ à 100$ manuel et 400 à 1000$ auto
Intake filter 55$ à 300$
Filage,huile gasket, 100$
Power steering pump et hose 300$ a 500$ pour Hicas ou Sohc seul.
Changer cluster sohc sur un 89-90 75$ a 500$
Option: Clutch act our centerforce 500-600$
Option: Turbo timer 200$
Option: Gauge pod autometer 50$
Changer le cable du cruise control sur 89-90 pour un 91-94
Bye bye antilock brakes!
Upgrade pour avoir 300hp-325hp
t28 bb turbo ou t3/t4........
Z32 ou Cobra maf
480 à 550 injecteurs
Intercooler core 20x6x3 1200$
Reprogrammer ECU 1000$ pour injecteur et maf ou Apexi afc 700$
Plus gros radiateur 2 core 300$
------------------------------------ SR 20 DET is life !! -----------
Vendeurs de SR20DET
Sunrise
514-324-6444
Osaka
514-382-4333
Japan Motor Import
514-369-3330
Engine Land
514-325-0888
Dynamique 2000
450-443-5558
1-866-443-5558
1308 Soucy, St-Hubert
Nagano Japanese
514-329-0001
1-866-240-0001
8515 Champ d'Eau, St-Léonard
Les installateurs reconnu!
Marco
Automotion (Greg ou Alex) 514 369-8808
Pour un rebuilt de turbo
Turbo expert
1-800-363-4648
Voici les personnes sur le site qui ont déja un SR20DET et qui pourraient vous guider un peu plus...
Vous pouvez les contacter via e-mail en cliquant sur leurs noms ci-dessous ou ouvrir un thread dans la section technique a leurs nom, exemple de sujet de thread: @nx2000
Mais prière de faire une petite recherche dans les anciens thread avec l'option search du board avant de poser des questions déja répondus
mixdrc
Halo
Navix
nx2k
Pat
nismo81
FrOm a2z
Super Silvia (Automotion)
White240sx
AyrtonSennaD
S14 Drift ! (no e-mail available)
nx2000 (no e-mail available)
[Edited by RavingZeus on January 23rd, 2003 at 10:13 PM]
ANd not the crappy one they sell at caca tires...
THe REAL nissan factory service manual.
the other one is not worth shit.
On the other and I got a PDF of the S14 silvia one...
http://www.zilvia.net/faqs/faqs.asp
- Scanned Parts Catalog in GIF Format
- Scanned Factory Service Manuals in PDF format
- Wiring Diagrams
http://www.srswap.com/ (Really good site , Lots of info n Picture)
- Look in (SR Install FAQ )
Which SR20DET to buy?
How much does it cost?
What parts are needed?
Step-by-Step Install Guide
Payment & Shipping info
Wiring Information
Auto Manual transmission swap
Trouble Shooting Guide
Old FAQ Here Parts
Cross Reference
MAF Wiring Charts
Ignitor Wiring Charts
Terminologie NISSAN
ONEVIA = S13 Silvia avec un devant de 180sx
SILEIGHTY = 180sx avec un devant S13 Silvia
ZENKI = Premiere génération de S13 (US 240sx 89-90)
CHUKI = Deuxième génération de S13 (US 240sx 91 @ 93)
KOUKI = Troisième génération S13 (N'a jamais vu le jour aux US, mais au Japon c'est S13 1994-1998, c'est les 180sx avec le SR20DET black top)
KOUKI tailights = Troisième génération de tailights 180sx (Celles formées de deux ronds)
180SX taillights = celles qu'on a ici
La définition que j'ai trouvé de TOUGE = "A cute, winding mountain road"
FRONT CLIP = La moitié devant d'une voiture
un front clip, c'est coupé comme ça
http://www.dhracer.com/fr/4images/d...p?image_id=1642
désolé je sais que la photo est sur un site qui n'a aucun rapport avec les autos, mais c'est le seul endroit que je connaissais ou on peut uploader des pics rapidement et facilement
Vtc Vve Vvl Ve,k
Hitachi Unisia Automotive has a variety of variable valve systems to offer. These have been developed with priorities ranging from performance to application, so that they can also be offered as sub-systems.
The three systems introduced here all improve fuel consumption and emissions while maintaining engine torque output in any driving situation.
Such systems are indispensable not only for vehicle to be produced in the future but also for current models.
VTC : Valve Timing Control System
VVL : Variable Valve Lift System and Timing
VVE : Variable Valve Event and Timing System
VE‚k : Continuous Variable Valve Event and Lift Control System
EVA : Electromagnetic Valve Actuator
Features
Hitachi Unisia Automotive's unique compact design.
Low friction characteristics make use at low engine RPM possible.
Applications
Cam be installed without valve train modification.
Cam be installed both intake and exhaust camshaft.
Cam be combined with VVL or VEL.
Features
Lightweight construction.
Compact design
Easy engine installation
Low friction
Applications
For swing-arm valve train.
Cam be combined with VTC or VEL.
Features
Cam be installed on any engine with direct acting valve train.
Cam be installed on any engine.
Applications
Cam be combined with VTC.
Features
Continuous change mechanism for both valve lift and event from lowest lift (or 0 lift) state to a long event and high lift state.
Low driving friction owing to desmodromic princple.
Quick changing response by electric powered actuator, enabling non-throttling load control.
Applications
For direct-acting and swing-arm valve train.
Can be installed in conventional cylinder-head without need of cam-shaft axis position change from conventional position.
Freely adjustable valve characteristics combined with VTC (Ultimate System).
when i have the time your all getting rep points i came in here cause i love the 240sx and i was gonna ask some questions they're all answered!!!! :bigup: thanks
Sr20det RWD Ecu:
E5 is from a 94-96 180sx black top 5 speed
E6 is from a 94-96 180sx blacktop automatic
WC is from a 94-98 S14 Silvia
62 is from a 91-93 180sx or S13 Silvia 5 speed
61,63 is from a 91-93 180sx or S13 Silvia automatic
J4 is from a 97-98 180sx Type X 5 speed
Factory Service Manual FSM - All 240SX model (175mb file)
http://www.neteasier.com/240sxfsm.zip
S13 & S14 Nissan parts catalog
http://www.ctech.ca/npclub/s13parts/
http://www.ctech.ca/npclub/s14parts/
Specs of 240SX (s13 and s14)
I'am updating the link of Develish..
S13
http://forums.neo240sx.ca/viewforum.php?f=7
S14
http://forums.neo240sx.ca/viewforum.php?f=8
sr20det ECU pinout From tru on npclub
1 Coil pack 1 output (via power transistor Unit)
2 Coil pack 2 output (via power transistor Unit)
3 Tachometer signal output
4 ECCS relay
5 Ignition pulse monitor (for trip comp ?)
6 Ignition Signal Ground
7 RX data (signal from Nissan Consult hand terminal)
8 Coil pack 3 output (via power transistor Unit)
9 Coil pack 4 output (via power transistor Unit)
10 -
11 -
12 A/T signal DT3 (autotrans gear select ?)
13 Ignition Signal Ground
14 CLK clock (timing signal) ?
15 TX data (signal to Nissan Consult hand terminal)
16 AFM Signal input (air flow meter)
17 AFM ground
18 Water temp sensor input
19 Oxygen Sensor input (O2)
20 TPS input (throttle position sensor)
21 Sensor ground
22 CAS 180deg signal (crank angle sensor)
23 CHK check (check start) ?
24 Monitor check lamp (Red) (fault code lamp output)
25 Exhaust over temp warning lamp output
26 Exhaust temp sensor input (behind the Cat)
27 Detonation sensor input (knock sensor)
28 TPS for A/T (kick down switch)
29 Sensor ground
30 CAS 180deg signal (crank angle sensor)
31 CAS 1deg signal (crank angle sensor)
32 Speed sensor input
33 -
34 START signal (from ignition switch)
35 A/T neutral switch input
36 IGN (ignition ON, from ignition switch)
37 TPS power output (power to throttle position sensor)
38 ECCS power
39 ECCS ground
40 CAS 1deg signal (crank angle sensor)
41 A/C on input (Air Con ON from A/C panel or climate control)
42 A/T signal DT1 (auto trans gear select ?)
43 Power steering switch (speed proportional control output)
44 A/T signal DT1 (auto trans gear select ?)
45 Ambient air temp sensor input
46 ECCS backup power
47 ECCS power
48 ECCS ground
101 Injector No 1 drive output
102 EAI control solenoid output (EGR valve control ?)
103 Injector No 3 drive output
104 Fuel pump relay output
105 Fuel pressure control module
106 A/C on output (Air Conditioner on relay signal)
107 Injector ground
108 Injector ground
109 Reverse electrical flow return circuit (alternator fail input ?)
110 Injector No 2 drive output
111 Turbo boost pressure control solenoid (over boost cut ?)
112 Injector No 4 drive output
113 AAC valve control (Auxiliary Air Control, idle speed control)
114 -
115 -
116 Injector ground
ca18det ECU pinout From tru on npclub
ECU PINS - Description of use
1 - Coil pack 1 output (via power transistor Unit)
2 - Coil pack 2 output (via power transistor Unit)
3 - Coil pack 3 output (via power transistor Unit)
5 - Boost pressure control solenoid (domestic Japanese cars only, not Euro models)
6 - Air conditioner relay
7 - Tacho drive output to tachometer
8 - Variable intake butterfly control solenoid (domestic Japanese cars only, not Euro models)
10 - Ground
11 - Coil pack 4 output (via power transistor Unit)
16 - ECCS system relay (earth = on)
17 - Injector pulse duty output (to trip computer for fuel usage measurement)
18 - Fuel pump relay (earth = on)
20 - Ground
23 - Knock sensor input
26 - Air flow meter pin B (ground ?)
27 - Air flow meter pin A
28 - Coolant temp sensor input
29 - Oxygen sensor input (unleaded catalyzer model only)
30 - Sensor earth
32 - Check lamp output to check connector (green)
33 - Check lamp output to check connector (red)
37 - Air flow meter pin D (non cat models ? )
38 - Throttle Position Sensor potentiometer (wiper)
41 - Crank angle sensor 180 deg input
42 - Crank angle sensor 1 deg input
43 - start signal (cranking) from ignition switch
44 - Neutral(manual) / park(auto) gearbox switch signal
45 - Ignition On switch signal
46 - Air conditioner thermostat input (ECU controls AC activation)
47 - To check connector ?????
48 - TPS potentiometer battery output (5 volt?)
49 - Battery from ECCS relay
50 - Ground
51 - Crank angle sensor 180 deg input
52 - Crank angle sensor 1 deg input
53 - Speed sensor input via the speedometer
54 - TPS switch (throttle idle position)
55 - Ambient air temp sensor input (sensor is in front of radiator)
56 - ?????
57 - TPS switch (full throttle position)Auto trans? (kick down switch)
58 - battery, unswitched
59 - battery from ECCS relay
60 - Ground
101 - Injector No 1 drive output
103 - Injector No 3 drive output
106 - AAC (aux/idle air control) valve output
107 - Injector drive ground
108 - Injector drive ground
109 - Battery from ECCS relay
110 - Injector No 2 drive output
111 - ? CA18DET A/T ? or pressure reg control valve?
112 - Injector No 4 drive output
115 - Heater output for O2 sensor (unleaded catalyzer model only)
116 - Injector drive ground
240sx brake upgrade SPECS
http://www.npclub.com/bb/showthread.php?s=&threadid=8001
Reading the fault codes on your CA18DET ECU
http://www.npclub.com/bb/showthread.php?s=&threadid=8074
300ZX (Z32) brake conversion for 240SX
http://www.npclub.com/bb/showthread.php?s=&threadid=6665
S13 Silvia Front End Conversion info
http://sr20.hybrids.jp/installations/silvia_front/
ECU Wiring Diagram for 240SX 91-92-93
http://www.ctech.ca/npclub/npclub/reparation/ecu-diagram.jpg
How-To do a Self test KA24DE ECU diagnostic (french)
http://www.npclub.com/bb/showthread.php?s=&threadid=4548
