Gregster
I finally had the chance to start work on my beloved Neon. This afternoon I turned my phone off and set to work on taking her apart for the next level.
First thing I wanted to do though was attach the new brakes to figure out what size spacers I would be needing. After I made redneck spacer from washers I think a 25mm kit at all 4 corners will do the job.
After that was done I set about removing the dash. My goal is to clean up the wiring up and get rid of all the useless stuff that I don't need. Removing the sound deadening is also on the list, running a race header with 1 5/8 tubes will cause burning.
