Teknotik.com
Bleeding your brake lines has never been easier with the patented Speed Bleeders. Speed Bleeders replaces the original bleeder valve in your caliper/wheel cylinder with a spring-loaded one-way ball and check valve design. Loosen the Speed Bleeder 1/4-1/2 turn and press down on your brake pedal. When the pedal is depressed, the pressure generated opens the check valve letting air and old fluid out. When you release the pedal to the up position, the valve closes and prevents any air from re-entering the line. It’s a real time saver! Available at Teknotik in full sets of 4. Please let us know your application to conform fitment.
www.teknotik.com
inquiry@teknotik.com
(416) 907-3851
msn: 4nperformance@canada.com
www.teknotik.com
Looking to redo your complete braking system? Feel free to inquire about our full line of braking products:
PACKAGE DISCOUNTS AVAILABLE
Brake Fluid: ATE, MOTUL, Wilwood
Brake Lines: Russell and Goodridge
Brake Pads: Hawk, KVR, EBC, Ferodo, OE Honda Replacement, Aftermarket
Brake Rotors: EBC, Powerslot, Brembo (Blanks and drilled/slotted), DBA, OE Honda Replacement, Aftermarket
Need a step up? Also available by special order:
Wilwood, Endless, Spoon, Brembo, Stoptech, Ksport, Project Mu, Rotora
Contact Info:
Phone Main: 416-907-3851
Phone 2: 647-344-6816
Phone (Dealer line): 416-751-1541
General Email: inquiry@teknotik.com
Eric: eric@teknotik.com
Jay: jay@teknotik.com
Address, map and store hours can be found here: http://www.jdmrides.ca/forum/teknot...m-engines-installation-fabrication-t1575.html
RUSSELL PERFORMANCE IMPORT SPEED BLEEDERS OFFER:
- Makes bleeding brakes a one person task
- Available to fit virtually any hydraulic brake or clutch system
- Sold 2 per package and offered in both metric and standard sizes (this sale includes all 4)
- Uses OEM style sealing area to guarantee a positive leak-proof seal
- Dust protection cap is standard with each bleeder screw
- Speed bleeders permanently replace original bleeder screw
NOW AVAILABLE FOR: 39.99$ (All 4)
www.teknotik.com
(416) 907-3851
www.teknotik.com
Contact Info:
