P2R Power Rev Racing Products Now Available
KNS Autosport
KNS Autosport is proud to Introduce the complete P2R Power Rev Racing product lineup.
Some of many P2R products:
P2R Honda CRV K24 BracketDoing a K24 swap? No need to go to Honda to get this bracket anymore. P2R now offers you a better solution. This bracket weights in at only 310 grams, while the Honda bracket weights in at 805 grams.
P2R Rear Tow Hook
P2R Rear Tow Hooks are made from 6061 aluminum, and are anodized for a show quality finish. Comes with necessary hardware for installation.
P2R K20 Thermal Intake Manifold GasketP2R Power Rev Racing intake gaskets will help reduce intake air temps.
P2R Liquid Fuel Pressure Gauge - 1 1/2
P2R Power Rev Racing liquid filled fuel pressure gauges have a black background with bright red pointer.
P2R J Series Exhaust Manifold Flange Type 2
P2R J Series Exhaust Manifold Flanges are 3/8 inch thick and made out of mild steel.
Complete Product list:
ACCESSORIES
Battery Tie Down
Battery Tie Down (Red)
Battery Tie Down (Gold)
Honda EGR Block Off Plate
Honda EGR Block Off Plate (Red)
Honda EGR Block Off Plate (Gold)
Vacuum Block
Vacuum Block (Red)
Vacuum Block (Gold)
H22 Euro R Fuel Rail Adaptor
01-03 CL,TL Battery Tie Down (Black)
Heavy Traction DVD
Heavy Traction Vol.2 DVD
Shift Knob - M10 x 1.5
B Series Spark Plug Wire Cover (Black)
B Series Spark Plug Wire Cover (Red)
RSX Battery Tie Down (Black)
RSX Battery Tie Down (Red)
RSX Battery Tie Down (Gold)
Rear Tow Hook (Black)
Rear Tow Hook (Red)
Rear Tow Hook (Gold)
Front Tow Hook (Black)
Front Tow Hook (Red)
Front Tow Hook (Gold)
APPAREL
Dog Tag Necklace
T-Shirt S Red
T-Shirt M Red
T-Shift L Red
T-Shirt XL Red
T-Shirt XXL Red
Mechanic Gloves M*
Mechanic Gloves L*
Mechanic Gloves XL*
Mechanic Glvoes XXL*
THERMAL INTAKE GASKETS
Honda
GSR
K20
B16A / Type R
K24 Mid Section
B18 / B20 Non Vtec
D Series
H22
S2000
Fit
01-03 CL Type S, 02-03 TL Type S
H23
06-09 Civic Si
04-08 Acura TSX
2004-2010 Acura TL
2003-2010 Honda Accord V6
2006-2010 Honda Ridgeline
2010 Honda Accord Crosstour
2010 Acura TSX V6
D17
2008-2011 Accord 4 Cylinder
2009+ Acura TSX 4 Cylinder
2011 Honda CR-Z
Mitsubishi
Evo
Eclipse 2nd Gen
Eclipse 1st Gen
Nissan
350Z
S13 SR20
S14-S15 SR20
KA24
Mazda
89-92 Rx-7 Non Turbo
89-92 Rx-7 Turbo
Porsche
92-95 Porsche 968
THERMAL THROTTLE BODY GASKETS
Honda
06+ Civic Si
B series Standard
B Series 60mm
B Series 65mm
B Series 68mm
B Series 70mm
04-08 Acura TL
2010 Acura TSX V6
B Series 72mm
00-05 S2000
01-03 Acura CL-S, 02-03 TL-S
02-04 RSX-S, 02-05 Civic Si
06-08 Acura TSX
06-07 Honda Accord
01-03 Acura CL,TL-P
04-05 Acura TSX
03-05 Honda Accord
94-95 Integra GSR
09 Acura TL SH-AWD 3.7
B Series 74mm
02-04 RSX-S, 02-05 Civic Si 70mm
09+ Acura TL 3.5
06+ Civic Si 70mm
05-06 Acura RSX-S
88-91 CRX-Si
90-93 Accord
Mitsubishi
1st Gen Eclipse Turbo/Non Turbo
1st Gen Eclipse Turbo Only
FUEL
B Series Fuel Rail (Black)
B Series Fuel Rail (Red)
K Series Fuel Rail (Black)
K Series Fuel Rail (Red)
K Series Fuel Rail (Gold)
Fuel Psi Gauge Set
Honda Fuel Filter Bolt
K Fuel Rail Bolt 3/8 npt
B Series Center Return Race Fuel Rail
D Series Fuel Rail (Black)
D Series Fuel Rail (Red)
J32A2 Fuel Rail
J32Z3 Fuel Rail
K Fuel Rail Bolt -8an
Toyota
4AG Big Port Fuel Rail
4AG Big Port Fuel Rail (Red)
ENGINE
LS/Vtec - B20/Vtec Dowel Pins
K20 Power Plenum (Black)
K20 Power Plenum (Red)
K20 Power Plenum (Gold)
Cam Seals
01-03 Acura CL,TL-S Power Plenum
08 Accord V6 Ported Intake Runners*
01-03 CL,TL-S Ported Intake Runners*
04-07 Acura TL Ported Intake Runners*
08+ Accord Ported Intake Runners 4 Cylinder*
K20 Power Plenum w/ Vacuum Ports
01-03 Acura CL, TL-S Test Pipe*
ADAPTERS & FLANGES
RBC Throttle Body Adapter
RBC TB Adapter w/ Vacuum
RBC TB Adapter 70mm
RBC TB Adapter 70mm w/ Vacuum Ports
RBC to Mustang TB Adapter
75mm Mustang TB Flange
80mm Mustang TB Flange
RRC Adapter
01-03 CL-S TB to 09 TL SH-AWD Intake Manifold
04-08 TL Big Bore TB Adapter
90mm Mustang TB Flange
Honda MAF Aluminum Flange
THROTTLE BODY SPACERS
06+ Civic Si
06+ Civic Si (Red)
06+ Civic Si (Gold)
04-07 TL
2010 Acura TSX V6
06+ S2000
02-04 RSX-S
02-05 Civic Si (Red)
02-04 RSX-S (Red)
02-05 Civic Si
01-03 CL,TL-S
01-03 CL,TL-S (Red)
06-08 Acura TSX
00-05 S2000
99-00 Civic Si
99-00 Civic Si (Red)
99-00 Civic Si (Gold)
07 Nissan Sentra Spec V (Polished)
05-06 Acura RSX-S
01-03 CL, TL-P
04-05 Acura TSX
06+ Civic LX,EX,DX
06+ Civic LX,EX,DX (Black)
06+ Civic LX,EX,DX (Red)
09+ Acura TL 3.5
06+ Civic Si 70mm (Black)
06+ Civic Si 70mm (Red)
VALVETRAIN
B Series - High Comp Valves, Standard Size
K Series - High Comp Valves, Standard Size
H22 - High Comp Valves, Standard Size
D16 - High Comp Valves, Standard Size
Valve Seals - Most Honda/Acura Vtec
Valve Seals - Most Honda/Acura Non Vtec
Bronze Valve Guides - B Series Vtec
TURBO ACCESSORIES
Turbo Oil Drain Flange T3/T4
Turbo Oil Feed Flange (Black)
K20 Log Manifold*
B Series Log Manifold*
D Series Log Manifold*
Intercooler
EXHAUST COMPONENTS
2.25" Resonator 15" Length
2.50" Resonator 15" Length
3.00" Resonator 15" Length
2010 Toyota Tundra Back Half Exhaust System*
GAUGES
Water Temp Gauge - 2 5/8
Oil Temp Gauge - 2 5/8
Oil Pressure Gauge - 2 5/8
Boost / Vac Gauge - 2 5/8
Liquid Nitrous Psi Gauge
GAUGE ACESSORIES
2 5/8 Black Trim Rings
Bulb Covers - Green/Red
AIR FILTERS
3" by 6" Tall
4" by 4" Tall
B Series Intake
CL 4" Intake (Auto)
CL 4" Intake (6 Speed)
SUSPENSION
06+ Civic Rear Lower Tie Bar
RSX-S Rear Lower Tie Bar
RSX-S Rear Lower Tie Bar (Red)
96-00 Civic Rear Lower Tie Bar
96-00 Civic Rear Lower Tie Bar (Red)
DRIVETRAIN
6 Puck Clutch - 03 Acura CL-S, 04-06 Acura TL*
06+ Civic Short Shifter
02-06 Acura RSX Steel Braided Clutch Line
06+ Civic Steel Braided Clutch Line
08+ Accord Steel Braided Clutch Line
09-10 Acura TSX Steel Braided Clutch Line
08+ Accord V6 Steel Braided Clutch Line
04-08 Acura TSX Steel Braided Clutch Line
03-07 Accord V6 Steel Braided Clutch Line
04-08 Acura TL Steel Braided Clutch Line
2011 Honda CRZ Steel Braided Clutch Line
MOUNTING BRACKETS
Honda CRV K24 Bracket (Black)
CLAMPS
T-Bolt 2 1/4
T-Bolt 2 1/2
T-Bolt 3
