frankyg37s6mt
its better for you car to get a tune MY G37 is way faster than stock and runs better
every dyno is different iand this MUSTANG dyno reads VERY low i had 235WHP B4 TUNE THEN i got 264WHP@6400RPM on that SAME dyno and 320WHP@7500RPM on another DYNo dinojet,,, i have roughly about 375 CRANK HP,,,,,,SO THE DYNO its not for (NUMBERS) IS TO TUNE and TO COMPARE ONLY SO FORGET THE HP NUMBERSIs it me or 210whp with all the bolt-ons doesn't make sens at all?
210whp is far from the claimed 300 crank hp...Plus you have all the bolt-ons...
That dyno doesn't look more accurate, it looks totally off...Unless Nissan was
claiming a fake 60hp....
Did a gtm supercharger on a nismo 370z like I said before and from the factory the Z has 350hp. With the supercharger it did 352whp on a mustang dyno but the car feels stupid fast now. Dont be fooled by dyno numbers especialy dynojet vs mustang dyno.Is it me or 210whp with all the bolt-ons doesn't make sens at all?
salut j ai une g35 6mt 05 jvien d installer un short ram et je pensais me commander un test pipe et une ligne d exhaust complet est-ce que le check engine dervrais coder avec le test pipe
Et pour ceux qui s'y connaissent moin en tuning d'ecu, n'importe quel tuner expérimenté peut tuner avec Osiris, vous pouvez donc choisir votre speed shop préféré...
hey whats up..
just wanted to post a thread.. regarding the Uprev Osiris Tuning Software.
good for all G35/350Z's and G37/370Z's..
for those of you that have not heard of Uprev.. its basically a tuning software.. that Flashes the ecu directly.. no piggyback garbage stuff.. Greddy e-manage junk, it is considered one of the best ways to tune for the Vq engine.. even for turbo and Supercharge setups..
after reading up about it on the Uprev Website.. I realized there was one shop in all of Quebec.. that carried and was capable to tune with this software..right in Laval..! Finally a reliable shop for tuning for the Z.. whcih ive searched forever to find..!
and that would be Johnny's Motorsports.. you can check out his facebook page or see his webpage
http://www.jonsmotorsports.com/
Johnny is super nice.. and is definitely a pro tuner.. he'll make your experience enjoyable while there lol...
with a beautiful Mustang Dyno at hand right in his garage.. also known as the HeartBreak dyno..for posting much lower numbers then other dynos.. but that would be cause its much more accurate..
ive seen stock 350Z's on other dyno's posting 265whp.. which is obviously BS..
after he did his magic with the uprev software.. the car gained a good 21whp.. on the spot.. wether or not my existing boltons helped.. this is a real gain.. simply by optimizing the ECU...
base line it made 211whp and 214wt, after tune it made 232whp and 216wt.
i was quite surprised myself.. with the base run..? but numbers are irrelevant unless you are FI.. all that matters is the car pulls hard..! ive been thinking of going FI for a long time.. but this is definitely satisfying for now..
2 hrs dyno time $150/hr and $300 for the Uprev License.. and your Z or G will run better and have more power.. then any bolton.. I know cause I basically have them all.. and none offered completely noticeable power.. compared to the uprev tune..
youre thinking to get an intake.. approx $400, an exahsut.. $600+ etc.. forget it.. get the car tuned.. first.. then get the other stuff.. but obviously as you add other parts.. it would be wise to get tuned again.. once you have the license.. all you have to do is pay the dyno time..
anyways.. jsut thought Id let you know.. cause car is way more fun to drive..
Tony.
