darkestfenix
There are about 4-5 huge ant colonies around the house. They just keep coming back no matter what quick fixes I tried. So hopefully this will be a long term solution that can help everyone else on MR.
Stuff you need:
-Bought some Borax at walmart (~5$) in the laundry detergent section (Enough to kill ants for your entire life)
-strawberry jam
-Bottle caps
-Nails with flat heads
-one spoon/bowl to mix
Mix 10 tablespoons of jam and half a tablespoon of Borax together. (1:20 ratio)
Pass your nails by hand through the bottle caps.
Shove the caps where ant activity is present and put your mix inside.
I went and put them outside and here's how they look right after I washed my hands and came back outside.
At the price it costs and if it rains, it washes away, I could go for weeks applying this stuff.
Keep you up to date with activity.
They should be gone in a few days.
First update (June 6th)
Came back to the two largest colonies. The bottle caps were practicaly empty. There was only one or two drops of poison left. Made a new batch, slightly stronger, and refilled. (Ratio: 4.5 spoons of jam + 0.3-0.5 spoon of borax = 6-10% borax)
See where it goes.
Stuff you need:
-strawberry jam
-Bottle caps
See where it goes.
