Karim E36
I have been having brake fade issues after a few laps.
I am considering brake ducts but want to sort out the current situation first.
My brother has the same car as me with a very similar setup. The only difference is that he has slightly softer springs front and rear (440/340 vs 340/280). He does not experience brake fade as bad. We have the same brakes, same tires, same weight,...
Last monday, we did a session where I would follow him closely on the track.
I was extra careful with my braking technique, trying to brake hard but for as little time as possible.
At the end of the session I measured the surface temperature of our rotors with an IR pyrometer:
Me: front 400+ F, rear 300F
Him: front 350F, rear 325F
(this is after a cool down lap for both of us)
Question: Why are my front discs getting much hotter?
It seems counter intuitive. With the stiffer springs, I would imagine my car would experience less weight transfer to the front. The greater temperature difference between front and rear on my car seem to indicate that the front brakes are doing more work. What can be the cause of this? Problem with the bias?
Any other ideas or suggestions as to what may be the cause of this?
Thanks for the input.
Karim
Karim
