od_man99
I wear headphones/earbuds for quite long periods. I consider myself an amateur audiophile. I thought I'd review my experience with two very popular designs.
For 15 months I owned and used, on a daily basis these guys:
The Good
These headphones were quite good. They offered decent, though a tad sluggish sound. They did sit well in the ear though and they wouldn't fall out on the casual jogging or the intense weight lifting events. I would use them between 2-3 hours per day at low volumes and they were pretty comfortable.
The Bad
Again, for anyone who loves music and look forward to faint notes these aren't the headphones for you. You don't get that bose crisp sound. Again, the bass feels off and in terms of range I felt it was quite limited.
After about 14 months the wires started cracking and stripping. I felt that for the price 120$ they did their job quite decently and lasted about a year, which is what I expected or what I've experience with other brands.
I'd say on 5, I'd rate them a solid 3.
Shure Se215
I've used these for the past few days. After the bose broke, I read a bunch of reviews and decided to buy myself a pair. Note these are quite cheaper 89.99$ compared to the bose 99.99$.
The Good
Well, where to start? These headphones are the best I've ever owned. The design is flawless, they seriously cut all outside sound out. In terms of the quality of build, the part that goes into your ear is a small cushion like plug. Kind of like earplugs you'd use at a shooting range. The material quickly fills up your ear canal and gives great outside sound suppression, which I really didn't expect.
In terms of the range, wtv music you play you'll get excellent quality. Note I'm no expert, but let me tell you these headphones will give you goosebumps when they thump that low note or hit the highs. It's as if you are there and the artist is playing just for you. Again, the Shure Se215 are midrange headphones, you can buy the Se315 and Se425 and heck I'm going to consider them once these headphones get old.
The Bad
Well, I use these when I'm at work, in the lab, jogging or lifting weights. All four of the aforementioned activities require a bit of awareness of your surrounding environment. Considering I can't hear a thing when I have these headphones on, yes even at low settings, it's hard for people to communicate with me. Which is frustrating at times, but hell what could they have to say that's more important compared to wtv song or radioshow I'm playing .
Apart from the aforementioned, I would say the other issue is getting use to the fit. It takes a few hours to get use to the design of the outer lobe but once that is done you'll love them.
Overall, for the price, 90 bucks, I'd say easy 4.5/5.
I hope you guys find the review useful for your future purchases. I quite enjoy finding information before buying a product.
IE2 audio headphones
High quality audio with instrumental and vocal detail
Advanced design, durable materials for lasting quality
StayHear® tips for greater stability during exercise and other activities
Hours of comfortable on-the-go listening
Options available for music listening and mobile calling Compare
Bose® in-ear headphones set a high standard for sound performance that conventional earbuds can't match. They feature an enhanced acoustic design that helps music sound smoother and more natural.
Quality construction combines a secure fit with durability, making these headphones ideal for music whenever you want, wherever you go. And there are options for mobile calling with iPhone®, Android™, BlackBerry® and Windows® phones.
The Good
The Bad
Shure Se215
KEY FEATURES
Sound Isolating Design
Comfortable sound isolating sleeves block up to 37 dB of ambient noise. Sound isolation technology prevents outside noise from interfering with your listening experience, whether on-stage or on-the-go. Shure Sound Isolating Earphones require a proper fit to achieve the best sound.
Unmatched Personalization and Comfort
Ergonomic, Professional Design
Lightweight, low-profile shape with optimized nozzle angle is designed to rest comfortably in the ear.
Over-the-ear configuration keeps cables out of the way.
Detachable Cable with Wireform Fit
Durable Kevlar® reinforced cable allows easy replacement or customization.
Formable wire ensures secure placement, and over-the-ear configuration keeps cables out of the way.
Gold plated MMCX Connector has a lock-snap mechanism allowing 360-degree rotation for comfortable fit.
Fit Kit Includes:
Sound Isolating Sleeves
The role of the included sound isolating sleeves is twofold: blocking ambient noise and ensuring a comfortable customized fit. Because every ear is different, the Fit Kit includes three sizes (S, M, L) of the Flex and Black Foam Sleeves. Experiment with the size and style that creates the best fit for you—a good seal is key to optimizing sound isolation and bass response as well as maximizing comfort during extended wear.
Carrying Case
A soft-zip, compact carrying case is included to provide a convenient, tangle-free solution to store and travel with your earphones.
Two-Year Limited Warranty
The SE215 comes with a two-year limited warranty on materials and workmanship. See warranty information.
TECHNICAL SPECIFICATIONS
Speaker Type: Single Dynamic MicroDriver
Sensitivity (1kHz): 107 dB SPL/mW
Impedance (1kHz): 20 Ω
Noise Attenuation: Up to 37 dB
Frequency Range: 22Hz – 17.5kHz
Input Connector: Gold-plated 3.5 mm (1/8”)
Cable Length: 64” Detachable (at ear) with wireform fit
Color Available: Clear or Translucent Black
*In an effort to continually improve our products, technical specs are subject to change without notice.
The Good
The Bad
