Wally West
Piranha, tu peux aussi faire un build avec un quad core i7.
Mais regarde ce video avant:
Oh lawd thats bad... What a bunch or retardsSur samsung canada c est impossible d enregistré un ssd. Je vais re vérifier mes source, je te reviens avec sa.
Edit: Et voila, c est hardware canucks qui avais soulevé le sujet.
After numerous discussions with Samsung Canada, since they don't directly distribute their SSDs in Canada (all distribution is done through second and third party imports), they don't have a Canadian warranty attached. If you think that's bad, just try to RMA it through the US site and you'll not only be unable to register it but be prepared to pay two-way shipping and a ton of excess taxes, brokerage charges and duties at the border. (citation)
Donc, si ton ssd se brise, tu paye le shipping allez+retour+2 fois la douane.
If you get a 3GB one, just be aware that if you add a second you don't "get" 6GB, Resolve will still only access 3GB. Resolve doesn't support SLI/Crossfire so providing your MOBO supports them it's relatively plug and play - Resolve will see and use both it just wont 'combine' the VRAM.
K2000 from google says it has 384 cores. Slow compared to a games card such as GTX780ti that has 2880 cores.
Someone correct me, but why a Quadro card? With the same money you can get a NVIDIA GTX card with more memory (6GB). The idea that the cards get better driver support, I'm not entirely sure that is true or matters, as GTX drivers as pretty good.
I understand that the Quadro has 10-bit output as opposed to 8-bit for GTX card, but I would monitor via SDI card anyway.
Les GPU peuvent être pris en charge pour la puissance de calcul dans un cluster GRIP.
Je partage celui-ci. Un peu de porn avec 30unités logiques de GPU.
Jai aucune idée comment overclocker quoi que ce soit... J'ai toujours été sur du Mac...
Jai regarde les x99 et ca semble être un meilleur achat que l'ancienne génération de socket.
Pour ce qui est du cooling, y a t il moyen de ne pas toucher à l'eau et de rester froid / assez silencieux?
