Theroux_Performance_Montreal
K&N Air filter Cleaning kit Rechargeur . Ensemble de nettoyage Filtre Air K & N .
K&N Recharger Kit 99-5000 is designed to service your K&N oiled cotton air filter when it gets dirty.
The kit comes with K&N Power Kleen air filter cleaner and K&N air filter oil.
The 99-5000 Recharger Kit will restore air flow efficiency and will bring your air filter to like new condition.
K&N Power Kleen works to dissolve the dirt build up and old filter oil, then it can be washed away with water.
K&N air filter oil is included so that you can re-oil your air filter after cleaning.
This Recharger Kit comes with a 6.5 ounce aerosol can of oil and a 12 ounce bottle of K&N Power Kleen air filter cleaner.
K&N Recharger Kit 99-5050 is designed for cleaning your K&N oiled cotton air filter when it is time to be serviced.
The kit comes with K&N Power Kleen air filter cleaner and K&N air filter oil. 99-5000 will restore air flow efficiency and will bring your K&N oiled cotton air filter to like new condition. K&N Power Kleen works to dissolve the dirt build up and old filter oil, then it can be washed away with water. After the air filter fully dries re-oil your air filter then reinstall it.
This Recharger Kit comes with an 8 ounce squeeze bottle of oil and a 12 ounce K&N pump bottle of Power Kleen air filter cleaner.
K&N : 99-5000 99-0504 99-0606
K&N : 99-0050 99-0533 99-0606
$19.99
$19.99
