ScHyZo
Salut!
J'ai une fuel pump de Bugatti Veyron à vendre, part #WSP330.
Acheter 300$ USD, donc 350$ CAD + taxes 15% = 400$ CAD neuf
Flow chart:
Description:
This state-of-the-art German-engineered screw-pump sets a new standard in high-performance. The new dual screw-design exhibits high-flow with minimal pressure drop-off and heating while operating at elevated pressures. This pump technology is used as factory equipment in the Bugatti Veyron and other super-cars. This pump will support over 800HP+ reliably and quietly making it the best performing pump currently on the market. This pump is compatible with gas, E15 and diesel. This pump may be used externally or in the gas tank.
Length: 226mm
Diameter: 43mm
Inlet: 15mm barb
Outlet: 8mm barb
Terminals: (-) 5mm, (+) 4mm
ne fit pas dans ma tank a gaz finalement, donc elle a fais 3 dyno pull et p-e 2000 kilo l'été passé.
Prix 250$
Flow chart:
Description:
Length: 226mm
Diameter: 43mm
Inlet: 15mm barb
Outlet: 8mm barb
Prix 250$
