Mazda 3 idling low problem
squiggles
Member
My mazda 3 2007 2.0 is having idling problems when the car is cold. When i turn it on and drive the car before it warms up it idles low and the check engine and also power steering warning lights flash.( power steering is fine) if i let the car warm up (until the thermostat needle rises half way) the problems seems to disapear. Is itbthe throttle body that would Be doing this? Battery is brand new also.
Cheers
Clean the throttle body with brake fluid and the problem should stop. You always have to that when replacing the battery.
