Lambo and rotary engine
driftking88
J'ai vu sa passer sur mon feed ! Une shop d'ici va faire sa un swap 4 rotors dans une Gallardo !!!
Envoyé de mon Nexus 6 en utilisant Tapatalk
well...that's an interesting swap!
But I wouldn't have chosen a Gallardo as a chassis. Lambo V10s are lovely engines.
People slap American V8's in everything because it's easy, why not put a rotary in something?
C'est juste une Galardo. Laissez la shop faire le built et vous jugerez par la suite. C'est pas comme si c'était une pièce de collection...
This is an heresy... *td*
Or perhaps an indication that this specific car isn't all that special anymore?
I mean, now that it's affordable enough to be a PR stunt for a shop whose specialty (ie rotary motors) has stopped being relevant 5 years ago; perhaps it'd be a good time to let go of the pretend outrage.
I think it's cool a "local" shop has the balls to attempt something like this. I wish them all the best.
The car itself is not special at all, far from it. They built thousands of them. But the V10 Lamborghini engine on the other hand is the "soul" of this car. It is like taking a standard Rolex Submariner watch and replacing the Rolex automatic in-house movement by a Japanese quartz movement just for fun. Even if the watch might be working properly, the final result will be totally worthless...
Anyway, as a car enthusiast, I don't like the idea. If, on the other hand, you like it, this is your choice. I do not care.
a 4 rotor engine is probably worth more than a lambo v10 FYI
People swap american v8s because they are reliable as fuck, easy to work with and cheap in parts.
Pretty much the complete opposite of a rotary engine lol
Justement tant qu'à ça ils auraient pu juste faire simplement le traditionnel swap Ls.
Loll
Pourquoi se casser la tête avec un moteur qui consommera autant d'huile que de gaz?
Loll
La shop est spécialisée en rotatif, je pense que c'est assez simple à comprendre?
Facile à comprendre, oui. Intéressant.... pas vraiment. Le v10 était parfait.
Est-ce que j'suis le seul a trouver le v10 lambo "ordinaire" en terme d'éxotisme?
C'est quasiment un v8 audi 4.2 avec 2 cylindre de plus. Les blocks et le crankcase viennent littéralement de chez audi puis le final assembly se passe en Italie par la suite. C'pas pour rien que la S6 et la S8 y ont eu droit...
Beau marriage des technologies germano-italienne, sans aucun doute. Rien a dire pour les performances, mais de la à dire que c'est une des 8 merveilles du monde, pas sur.
Tant qu'à faire son snob, ça pas autant de cachet qu'un v12 lambo de A à Z ou qu'un moteur sorti tout droit des forges de maranello.
