Oil vs Natural Gas vs Electricity House heating
Mtlalex
Whos got experiance with Natural Gas??
Is it really that much cheaper than electric or oil heating?? I keep reading that it is but im curious how accurate those sites are??
What do you guys think?
faut vraiment que tu aie une grande maison pour que ca vaille la peine, les equipements sont assez dispendieux vs electrique
cmon this quesiton in 2018.... please. burning stuff VS using hydro....
Well, depends on your usage and installation cost.
then you can convert the energy used to $.
for heating, the smart choice still the heatpump in general.
La maison est deja equiper et as une thermo pompe. Jme demandais vraiment plus un niveau cout $ d'utilisation par mois... 2 maison coller meme dimention/utilisation. quelle coute plus cher? gas naturel ou electric?
Ya i get what your saying. But that wasnt the question.
Im more interested in knowing if the sites that are claiming that it can be up to 70% cheaper are lying or if there is some truth to it??
1 cubic meter of nat gas @ 0,335$ = 35915 BTU / 0,335$ (that is for 100% efficiency, which is not the case.)
35915 BTU = 10,53 kW @ 0,0912$ = 35915 BTU / 0,960$ (electric heat = 100% efficiency.)
Let's take into account a more reasonable 80% efficiency for a base model furnace, the price goes up to 35915 BTU / 0,419$. Roughly half the price of electricity.
Now that is for nat gas VS straight electric (resistive) heat, as per your question.
A heat pump with a COP of 2.3 would cost the same to run. Bring the COP up more and it starts to be cheaper than nat gas. However, in our climate, no central heat pump will maintain such performances during the colder days, taking defrost cycles into consideration.
Those are rough calculations but you get the idea.
Thanks thats interesting. Is the COP of a heat pump easily calculated or verifiable?
COP changes with outdoor temperature. In heating, it ranges from 0.9 to 2.X. The colder outside, the lower the COP. Not to be confused with capacity, as the capacity of a heat pump diminishes as the temperature drops as well. So the colder it get, the less efficient it becomes and it doesn't provide full capacity.
Oh ok I get it! Thanks
That's pretty much it. The best mini-splits have COPs as high as ~4 !
J'ai passé du mazout au gas naturel il y a trois ans et si s'était à refaire je changerais tous ça pour des plaintes électrique pour la simplicité.
J'ai une maison pas mal grande et le chauffage est central à l'eau. J'ai pas l'impression que l'a différence de coût entre le gas et l'électrique dois etre de beaucoup une fois calculé le cout du gas (il te charge un montants même l'été si tu ne l'utilise pas) plus le cout de l'entretien annuelle et le cout initiales et de remplacement dans plusieurs années.
il faut aussi considéré le tarif préférentiel d'hydro lorsque tu chauffe au gaz
j'etait sur ce program, mais j'ai debarquer vite....
25c/KWh quand il faut moins que -15 dehors
mon garage et chauffer a l'electro .... meme si je le mettait a 10 degree.... ca gonflais les facture pronto!
j'ai reswitcher cette hiver a program regulier
ca depend du cas par cas honnêtement
j'ai un systeme carrier neuf.... termopompe et fournaise serie "Performance" .... a date cette hiver je voit une baisse d'utilisation de gaz mais pas au point de faire un big deal...
Il y a peut-être une chose que j'aurais fait si je l'avais découvert avant c'est de louer pour de la géothermie. Et oui je savais pas qu'il y avait une compagnie qui s'occupe de forer le puits et de t'installer l'unité de chauffage pour le même prix que ce que j'ai payé pour le gas et les payement par mois sont similaires à ce que je paye pour le gas.
Surprised no one mentioned insurance premiums. Having a heating system that can burn down your house will cause a higher insurance premium. By how much, maybe call a broker but it's definitely something more than electric. If you're really getting down to the decimal places to calculate one vs the other it could make a difference.
Le taux bi-énergie vaut rarement la peine.
j'ai deja fait le calcul de tout mon electricité au taux regulier vs le total du taux réduit et surprime par temps froid...et je sauvais a peine 20$ par année.
Mais pour sauver ce 20$ par année: ca veut dire que a -12 et moins(quand la lumiere allume) tu deplace la plupart de tes activité de maison(lave-vaisselle, lavage..bref tout ce qui consomme)......pour 20$ et pas avoir a me cassé le cul..no way.
Sans compter la gestion de l'huile et la vérification des prix qui fluctu tout le temps (J'ai deja payer 1,25+ les taxe...sur 800l ca coute une beurré!
Ma nouvelle maison a une thermopompe, fournaise a l'huile et plinthe (la fournaise et thermo a été un ajout a la maison apres qlq année).
l'ancien proprio chauffait a l'huile pas mal. mais moi je part les plinthe quand il commence a faire froid et je joue avec la temperature demandé a la thermopompe pour la faire embarqué ou non.
Les tarifs modulés arrivent pour tout le monde (volontaires d'abord) l'an prochain anyways.
name of said company ?
