I am parting out my 1991 obd1 Honda crx turbo the car is in really good shape, but due to the nature of this beast I must part with it. I have been running her strong for 5 years. She beats 600cc super sport bikes on the highway and gears out at 308km/h through gear calculations and data logs. I have considered selling as a whole, but parting it out would be in my best favour
Here is the list and pictures will be added later.
91 crx dx shell clean title in my name papers in hand and ready for the new owner. The shell will come without suspension or front brakes no motor or cluster and it's pretty bare. It will have seats, dash, door panels etc.
$1500.00
B16a Jdm motor, build forged bottom end, benson sleeved, cp pistons and eagle rods. Tapp auto built. Head is held on by arp head studs, new oem Honda hg, timing belt, water pump. Head is built as well, valve springs and retainers along with Gsr cams. This is for the long block, no alternator no distributor, intake or exhaust oil pan is plumbed for turbo return and feed oil lines. This motor runs amazing and has no more than 20,000 kms on her. I changed the oil every time I took her out on the weekends with mobile 1 synthetic oil and a k&n oil filter or honda. 8 oil changes this summer.
Will come with plug wires (ngk) and plugs ngk
$2500.00 obo
Intake manifold is a edelbrock performer x
$300.00obo
B16 throttle body
$60.00 obo
Precision 880cc injectors 4x
$300.00
Stainless turbo exhaust manifold new price on her was $1400.00
A steal at $500.00
Precision sc61 turbo 61 cold and 63 hot little to no shaft play and doesn't burn oil
$400.00obo
Tial waste gate
$180.00 obo
Tial bov
$180.00 obo
Arc intercooler
$150.00
Aluminium Charge piping for crx civic etc without couplers or t clamps
$100.00
Tclamps and couplers $75.00 for all
Vw scirocco Ef custom tuck rad with Toyota inline rad cap and reservoir
$150.00
Ef 88-91 Honda crx, civic wagon, sedan or hatch hasport motor mounts cable included are the front left front right center rear motor mount complete kit of three mounts
$250.00 obo
B series axles left and right with intermediate shaft
$125.00 obo
Act stage 4 unsprung clutch and pressure plate
$300.00 obo
Lightened flywheel
$150.00 obo
B series ls cable transmission with quaif lsd
$800.00 obo
Crx dx obd1 b16 vtec custom tucked harness
$250.00
Rpf1 15" 41 offset
With Dunlop tires $900.00 obo
Volks te37 in amazing shape with slicks 15" 4x100 41 offset
$1250.00 obo
Steel braded lines 2x rears
$30.00
Jdm suspension with progressive springs and type r rear lower control arms
$400.00
Wilwood 11" front calipers and two piece rotors they come with wilwood front braded lines as well
$700.00
Front Ef traction bars
$150.00
Stainless cat back honda Crx 3" turbo exhaust
$400.00
Integra type r Jdm cluster
$100.00
Authentic Mugen 5 speed peddles 3x
$80.00
Auto meter boost gauge 30psi
$80.00
Aem wideband with sensor and all wiring ( complete )
$180.00
Hondata s300 on on obd1 ecu
$650.00
Walbro fuel pump 255
$80.00
B series's shift linkage for Ef
100.00
B series alternator
$100.00
Moroso distributor obd2a for Gsr but works on Ef with conversion harness
$150.00 and $30.00 for jumper harness obd2a to obd1
Down pipe, cut in two parts, one to go out hood and other to go down, wrapped
$100.00
Odessey Mini PC680 battery
$100.00
Gm 3 bar map sensor
$60.00
Turbo oil feed and return lines (return is an fitings )
$100.00
I can be reached at 613-276-3762 ask for Donny
All parts were tested and very well taken care of. They work perfectly and have never given me an issue.
$1500.00
$2500.00 obo
$300.00obo
B16 throttle body
$60.00 obo
$300.00
A steal at $500.00
$400.00obo
Tial waste gate
$180.00 obo
Tial bov
$180.00 obo
Arc intercooler
$150.00
$100.00
$150.00
$250.00 obo
$125.00 obo
$300.00 obo
Lightened flywheel
$150.00 obo
$800.00 obo
$250.00
Rpf1 15" 41 offset
$1250.00 obo
$30.00
$400.00
$700.00
$150.00
$400.00
$100.00
$80.00
$80.00
$180.00
$650.00
$80.00
100.00
B series alternator
$100.00
$100.00
$100.00
Gm 3 bar map sensor
$60.00
$100.00
