1987 Scirocco 8v (new info added)
Just seeing if there would be any interest in my 87 Scirocco 8v... The body is solid, some minor surface rust in some parts, but it's in great shape considering its age. This car has had almost everything replaced on it this past year... (see list below)... Basically, it doesn't need anything and won't for quite a while! Comes with winter tires and all receipts dating back to the early 90s, as well as a box with many extra parts. Was just safetied and e-tested in Ontario.
List of repairs done to it this year:
Front Rotors + Pads
Rear Drums
Driver side brake cylinder
Rear Wheel Bearings and Seals
Tune-up (plugs, wires, cap, rotor, O2 sensor)
Tranny fluid
Timing and accessory belts
Water Pump
Starter (being changed as we speak)
Alternator
Battery
Fan Switch
Reverse Light Switch
Exhaust Manifold Gaskets
Head Gasket
Valve Cover Gasket
Oil Pan Gasket
Front Ball Joints and Tie Rod Ends (and of course alignment)
Missing Linkz Shifter Kit
Asking: $1,500
Front Rotors + Pads
Rear Drums
Tranny fluid
Water Pump
Alternator
Battery
Fan Switch
Head Gasket
Valve Cover Gasket
Oil Pan Gasket
Asking: $1,500
