jerm__
Je parle français aussi.
Selling a bunch of items.
OEM
Lexus IS300 Passenger Headlight $175
2 x Toyota Exhaust Manifold Gasket (17173-46051) $20 for both
Lexus IS300 front grill (no emblem) $100
Exhaust
HKS Carbon Ti turbo-back for STi/WRX $350
3” PPE V Band Clamp (https://www.summitracing.com/int/parts/ppe-517030000/overview/) $45
Gauges
AEM Analog Air/Fuel Ratio $200
AEM Boost Gauge $150
AEM Oil Pressure Gauge $200
Fittings
4 x -10AN Straight Swivel Hose End - Vibrant (21010) $10 each
2 x -10AN 45 degree hose fitting - Vibrant (21410) $20 each
-12AN to 2 -10AN Y Fitting - Vibrant (10811) $40
2 x -12AN Straight Swivel hose end - Vibrant (21012) $15 each
7 x -4AN Straight Swivel Hose End - Vibrant (21004) $5 each
-4AN 90 degrees swivel hose end - Vibrant (21904) $15
2 x -4AN to 10mm 1.0 adapter - Russell (670500) $4 each
2 x -4AN to ⅛” NPT adapter - Vibrant (10293) $2 each
-4AN 90 degree power flow hose end black - Fragola (109004-BL) $20
-4AN to ¼ NPT straight adapter - Fragola (FRA-581605) $3
2 x -4AN Adapter - Aeroquip (AER-FBM5001) $2 each
4-AN to -4AN to 4AN Male Y adapter - Vibrant (10804) $20
-12AN Male Weld Bung - Vibrant (11154) $7.50
2 x -10AN Male Weld Bung - Vibrant (11153) $5 each
-10AN Male Weld Bung - TFS-51400815 $5
2 x -10AN turbo oil flanges with bolts $20 each
Stainless steel lines
6ft x -4AN - Summit Racing (SUM-230406) $25
5ft x -12AN - Vibrant (11942) $40
2ft x -10AN - Vibrant (11910) $15
Fuel
Aeromotive A1000 EFI Bypass Regulator (13101) $200
Walbro GSS342 Fuel Pump $100
Used stainless steel fuel lines Offer
Intercooler/Piping/Air
TiAL Black BOV Q 50mm $250
2 x CXRacing 2.5” Intercooler Piping Kit (Silver, black couplers, clamps) $100 each
4” K&N Air Filter (RE-0870) $55
3.5” 45 degree air intake piping $40
2” cast aluminum 90 degrees bend - Vibrant $25
Oil
Saikou Michi Dual Catch Can Setup $250
Mishimoto Oil Sandwich Plate Adapter with 3 ⅛” NPT Ports (MMOP-TPS) $50
Other
40ft of 20 gauge wire $5
MAXOUT Dry Chemical Fire Extinguisher (MX250R) $75
OEM
Exhaust
Gauges
Fittings
Fuel
Oil
Other
