En utilisant des tracker privé on réduit pas mal les risques ?
Sinon quelqu'un pourrait faire un post avec les precautions minimum a prendre ?
Merci pour les infos
oui. ca reduit de beaucoup les risques!
There is no real minimum.
Private Tracker is a good start.
Proxy is good for someone who just wants to block his IP address for use of torrents but it has to be very well setup to make sure your IP address is completely invisible to a swarm. People complain about DNS leaks. I was going to go with this until I realized for 13$ more a year I can get a VPN instead.
VPN is the same principle as a proxy but for
all of your internet and download needs, this can slowdown internet for some people. Plus you get to unlock websites with geolocation restrictions (for now) like Hola does. Same thing as proxy, it has to be very well setup.
Seedbox is basically a server located somewhere where you download all your torrents to and then you download your files directly from there. Your ISP doesn't know what you are downloading. The problem is they don't allow the use of their services on public trackers, which sucks for me, because production/distribution companies still send letters to seedbox providers and seedbox provider forwards the info to you and warns/bans you. This defeats the purpose of the service for me.
Usenet is for now the best/easiest/simplest choice but the biggest con is accessing "old" and "hard to find" stuff. So for me this eliminated this option as well.
Then there are people that push it to the limit and buy a seedbox, followed by a vpn, followed by a proxy, paid for by bitcoin. Kind of like Cryptkeeper explains above. This is being paranoid or you do mass content uploading and seeding and want to protect yourself.
Just don't ever forget, if someone wants to find you, they will. The only thing you can do is make it hard for them so the time and resources necessary to do it is not worth it. Because companies can still ask for the proxy, VPN and seedbox providers to hand over info. But it just complicates shit.
