I have for sale the following following items for LT1 Engines & 4Th Gen Camaro/Firebirds:
Super Clean LT1 Block Clearanced (Machined) For 383 Crank. This was a BRAND NEW block machined for a 383 crank. The paint on the outside of the block is perfect. All this needs to be used is to clean the gasket surfaces & a light hone. 2 bolt mani and 0.030 over. $200
Includes main caps but don't have the main cap bolts. Also includes rear main seal and oil pan.
Ported LT1 intake, port matched to AFR Heads & A Twin 58mm Throttle Body $100. Intake, Fuel Rails, Regulator, Some Sensors, NO INJECTORS. Painted Black & Red. $100
WILL SELL THE 383 BLOCK AND PORTED INTAKE TOGETHER FOR $250.
LT1 F Body Accessory Bracket & Accessoroes: Alt, PS Pump & AC Compressor $100
Bear Brake Brackets For C4 HD Brakes $100
Similar to the UMI ones in the link below but sized for C4 HD brakes not C5.
http://umiperformance.com/catalog/index.php?main_page=product_info&cPath=7_99&products_id=158
LT1 PCM From '96 Z28 $100
'96 Front Lighting & Chassis Harness $100
'96 Dash Harness $100
Prices do not include shipping or any form of delivery. WILL NOT DELIVER.
Package deals can be discussed.
PM me if you’re interested.
