dcaron999
I tried my mis-matched 255/35R18 squared setup on the track for three 20-minute sessions yesterday evening. The local ICAR track (cement pavement) was wet - it was raining for the first session.
I took pressure readings on my front tires before and after each session.
I started out with 32PSI cold front and rear. First session was on a wet track, I hardly got any heat into my tires. 2nd and 3rd sessions were on an almost dry track. With more speed and heat into the tires, this is where things got interesting, and Id like your educated feedback on.
Front tires (Michelin Pilot Sport RunFlats) only went up by 2PSI, and rears (Bridgestone RE-11) by 6PSI. This is the opposite of what I was getting with my previous staggered setup (255/40R18 & 255/35R18 RE-11's). During previous track days, the fronts were obviously getting overworked. The fronts use to go up by 6-10PSI after a 20 minute session on the dry. Now, the emphasis seems to have shifted to the back. Maybe the sidewalls in the Run Flats, and the lower 35 profile are keeping the front tires from rolling over and working harder. The rears are now working & sliding a little more.
For the first time at this track, I experienced no understeer, but the rear end was a little more twitchy. There was no rolling over onto the edges of the front tires or top of their sidewalls.
Do you guys think I should reduce the front camber (-3.2* and 0 toe) now that the meatier 255/35R18 tires seem to be staying more flat, and building up less heat?
Ideally, I know I should be doing pyrometer temperature readings across the tread to determine ideal camber setting, but what would you start off with?
Ive made a decision: No R-comps for now. Ill be sticking to a nice 255/35R18 extreme performance square street tire setup, until I "upgrade the driver" (more lapping and driving events).
