Ok well thought id update this thread since its been a while..
My wheelbearing started making noises on the front driver side, soo i picked up a full 1.8t/vr6 brake conversion to upgrade the shitty tdi/2.0 ones..
Pressed new bearings in and cleaned everything up good+paint.
Also put in new balljoints..
Fill the wheel up nicely now hehe
I also started getting a lot of axle bind after putting in a new axle..soo i realigned the engine towards the passenger aide to fix the issue
Besides that i started getting a very bad rattle..at first i thought it was the heatshield that was half loose..soo i ripped it out(if you own a mk4 its the long one that goes over and around the rear beam..was a bitch to get out..)
But the rattle was still there...started the car up and went under it to find out both the rubber hanger bushings holding the exhaust in place under the center exhaust crossmember were shot..soo replaced those aswell(no pics but there was barely anything left of those bushings)..now the rattle is fixed!
Next issue is my oil return line..im going to have to remove the oil pan and redo the oil return because its a hack job and has a leak from both ends..but that will wait untill my next oilchange..
Ill also be picking up a watermeth injection kit since my egts are wayy too high in the warm weather when i try to go full throttle..
While we wait for that time to come here are some pics
Pountnride 2016
Sent from my SM-G925W8 using Tapatalk
