lord_galathon
Edited, just scroll down for latest post.
I'm trying to figure out if special goggles are required or if normal (really dark) sunglasses are ok. I imagine the main issue is probably coverage as goggles go all around to the sides and normal sunglasses usually won't.
I'm thinking I will test refraction in my pool hihi.
OK never mind the very bright, this laser is retarded, after making a (couple of) hole in a black garbage bag, I just ignited a piece of black cardboard with it from a distance of about 2 feet, it started smoking after about 1 second of being focused (it's focusable) and I had to step on the cardboard to extinguish.
Not a toy. I will definitely not let my daughter play with this laser. It is wicked.
I will test with other black materials over the week-end, as well as matches and balloons, I have no balloons here but I can probably pick some up at Dollorama over my lunch later.
Also I want to see the range, will test later.
Tu es capable de faire bruler des trucs avec, pis tu l'a pointé vers ton oeil? :yikes: wtf t'es pas aveugle?
Oh shit, imagines maintenant dans ton oeil directementBen non je l'ai pas pointe vers mon oeil. C'est juste tellement bright sur une surface blanche que c'est aveuglant.
T'es un mechant cave, a 200mw et surtout avec son wavelenght, qu'un seul reflet sur un objet metalique dans l'oeil de quelqu'un et tu peux l'aveugler. C'et pas des lasers de depanneur, imagnine toi donc que c'est fucking dangereux.
amuse toi chez vous si tu veux, mais surtout pas dehors, et surtout, sans lunettes
