Drifter Steve
The transmission is crucial, not only for driving performance and comfort, but
also for fuel consumption. The new 911 Carrera models are the first cars in the
world to feature a 7-speed manual transmission as standard. The 7-speed
manual transmission (which was developed from the familiar PDK) is
characterized by its widely spaced gears. 1st through 6th gear is designed for
optimum acceleration. The car reaches its top speed in 6th gear. 7th gear is
provided to reduce the revs at high speeds and thus improve both comfort and
fuel consumption. Low engine speeds reduce the noise inside the car,
particularly on highways.
The recommended gear shown on the instrument cluster encourages
economical driving. In addition, the new gear indicator in the rev counter shows
you which gear you are in. The elevated front center console and the driver’s
seat position are designed to minimize the distance between the steering wheel
and the gear selector so that you can change gears quickly and safely.
