Hi guys, need some help,
Trying to remove my valve cover and have a few issues that I ran across. I'm doing this because I suspect that my catch can lines froze and built up pressure causing the gasket to blow.
I've managed to remove the ignition harness, and am about to start the rest, but need some advice to the below:
Car is 2010 Audi A4 quattro.
1st pic: Are these 3 bolts going to remove the cam adjuster solenoid that's bolted to the timing chain front cover?
2nd pic: I can see almost all of the bolts needed for the valve cover itself. This one circled in red is on the very front row, but is half blocked by the metal and plastic shown in the pic. How do you get to this bolt to remove?
3rd pic: To remove the high pressure fuel pump and vacuum pump on the back of the valve cover, there seem to be a series of very long bolts, but ONLY the first, top one, should be attached to the valve cover, correct? Once you start threading out the 10mm bolt, you can see the other end (in red) being threaded out.
