Killingcivics
My 1985 Mustang will be started today. Carb and all. It's not that cold.
Je cherche un code scanner assez bon pour effacer SRS.
Looking for code reader good enough to
erase SRS.
Honda says they did the recall, but SRS is on.
erase SRS.
Myth? If the transmission fluid has never been changed, don't change it? I noticed when cold my car was a bit hesitant to shift. Since today was nice out, i drove for 10 minutes, parked checked my level and noticed it was missing about a quart. I added a quart, and i'll only know tomorrow if that was the problem. I've been reading, everyone suggests to change the fluid, and the filter. People say if it's never been changed don't. My fluid was nice and pink still, didn't smell burnt, or have a brown tint to it. Do i leave it, or do a full flush?
Your has a dipstick? My A7 G37x didn't. You needed to fill it by the fill port on the pan with the engine running lol
BTW, that ATF myth about not changing it is based on some truth, but doesn't necessarily apply to all cars. New ATF has a lot of detergent, and the argument was that an old car will have gunk and grime from worn out clutches stuck everywhere inside the transmission that will be loosened up by fresh ATF. What happens then is that the clutch dust clogs up the succion filter which burns the pump. Then you're fucked.
Modern automatics usually have a screen strainer that won't get clogged by clutch dust, and transmission are built way better than an old TH350. Clutch materials and fluid technology has also evolved a lot.
If you want to be safe you can do several fluid flushes in a short period of time.
I have a dipstick. Vq35deYour has a dipstick? My A7 G37x didn't. You needed to fill it by the fill port on the pan with the engine running lol
same thing is said about switching a car that has ran for 200 000km on mineral oil to synthetic oil, for the same reasons he mentionned.
I need to change the pan. It's rusted too much to my liking. I might as well change everything while it's off. It has a filter, so I'll check it and see how bad it looks.Your has a dipstick? My A7 G37x didn't. You needed to fill it by the fill port on the pan with the engine running lol
Pas tout à fait.
Sur un char "moderne" aucune problème de passer à de la synthétique même à haut millage. Ce myth provient des plus problèmes avec des vieux seals secs qui pouvaient se mettre à couler sur des vieux chars... aujourd'hui y'a aucun problème.
Je l'ai fait sur mes Honda/Acura et un Jeep, jamais eu de trouble.
Toujours entendu dire que de switcher à la syntech remplie d'agents détergents après autant de KM pouvait dégommer du buildup et pouvais causer des dommages.
Mais perso j'ai toujours pensé que c'était des histoires à dormir debout
